Project Cindy, single speed cruiser build
The colour dilemma !
So I'm getting my paint mixed ...do I go for Original graphite grey which is pretty pretty rare on the Kona.. I can find only two other bikes in graphite grey. ..
for...
Retains the original look as kona intended.
Against, Maybe a little bland ? Already have a grey cinder cone. .
Audi moonshine blue metallic...
For..
Beutiful pearl hue with amazing colour pop which Changes from almost black to deep electric blue when the sun refects. Will look classy with polished aluminium components.
Against, potentially very difficult to apply and achieve decent finish. Very none kona stock colour.
Metallic black ..
for..
Everything looks good with black ..right ?
Against, nothing
All potential colours are metallic which I haven't sprayed in quantity and theres real potential for uneven laying of flake due to the nooks and crannies of the frame.
Decisions ..
I like the graphite or black option the best but just to chuck this in I'd fancy a white frame with black forks for a change as I've never had this and this it looks cool.
Go for the blue,no point having another grey if u have one that colour.
I had an old bike and Honda crx painted audi sprint blue peril and it looked stunning on them both.
:D Just got here in time for paint!
Right.... crack on then.... :LOL:
With the the dark nights drawing in rapidly and less time to play at weekends I needed to get the paint down. After much deliberation I decided to go for the original graphite grey which is a rare colour for the Cinder Cone. The nearest match to Konas original is Toyota, magnetic grey metallic. I’m wondering if this is a pearl finish as in certain light it looks almost black.
It’s a real faff suspending the frame to paint.. I need to look at alternatives for future projects :?
Previously id painted small car components in metallic finish but never a bike frame. A good tip I picked up from Youtube was to apply a final "drop coat" before clear coat which helps evenly distribute the metal flake in the paint.
With all paint removed the frame was 'scuffed' with 320 grit then 600 grit.
i De greased all tubes panel wipe solution applied with toilet roll until there was no signs of dirt/grease/crud remaining.
finally a tack cloth wipe down to remove any fibers left by the previous process.
Next in line ...
Naked ...
Panel wipe applied with toilet roll ..
Amazing the amount of crud to be removed...
Paint stripped, de rusted , de greased...
Quality welds ..
The 'jig' ... needs work :roll:
Final wipe down with tack rag ...
first dusting of etch primer ...
First dusting of primer ...
Final coat of Primer flatted with wet n dry
At this stage i had to move to the 'spray booth' (ginnel between our house and neighbors) as the wind had picked up,,
First dusting of base coat ...
Clear coat going on ..
All done ...
runs in clear coat will need addressing when paint fully cured.
OK, it is not the blue color I wanted you to paint the frame in but this gray one is awesome man!! Great work!
Why no bolts in bottlecage holes and why didn't you apply decals before clearcoat?
Edit: I think P2s in white would look crazy good with this!! Also white grips, pedals, saddle and cables... :)
Nice work Billy Bob!
