Yes but a bit too late to use hammers, and the left cup seems to have an extra bit in it so the tool won't fit either...
What's the extra bit? Something that could be drilled away/down so you could fit the tool? Is it like a spacer thing?Yes but a bit too late to use hammers, and the left cup seems to have an extra bit in it so the tool won't fit either...![]()
Yes it is like a sleeve inside the bearing going to try knocking it out in the morning.What's the extra bit? Something that could be drilled away/down so you could fit the tool? Is it like a spacer thing?
Last but one resort, stilsons will be the ultimate weapon...Have you tried using vise grips on the cups?
Reckon that'll do the trick. "Why do it properly when you can do it brutally?" - me, probably.Last but one resort, stilsons will be the ultimate weapon...![]()
I have one moving slightly, but like the coward I am, I am of to bed...Reckon that'll do the trick. "Why do it properly when you can do it brutally?" - me, probably.
