mforrest
Devout Dirtbag
That is not the main point for a try you could mix it up. The bottem part of the ball bearing is the same or could be used as a junit of its own. In the worst case you have to remove the top out of the frame and put a a-head ball bearing cup in there. Just try if the bearing and cup from the Marin fit to the upper.
As I already mentioned more important is the diameter and length.
Cheers Martin
Cheers Martin
