Shimano 600 5/6 Speed Gear Shift Levers - ISSUES!!
@Mr Weirdo I thought that 653 (mixed grade tubeset) was less durable than a 531Pro set. I assume it would depend on other factors determining your selection (condition, size, parts).
i think one of the biggest factors in durability of quality steel is how well the flux was cleaned off after brazing - many nice old frames fail from internal rust around the bb and bridge.
A heavier rider on a tubeset that's too light will find the bike feels too flexy - it's unlikely to break.
653 is the same gauge as 753, but an inferior material (different heat treatment). Tony Oliver's view in his book is that it's a bit on the light side and marginal. So that comes to a question of suitability: probably it will be fine in a small frame, but in a very large one it may be too flexy.
I love my Dawes Edge 653 MTB, but that has oversize tubes anyway, so is a different kettle of fish.
I have taken my information from this forum and articles on the internet. I have read that 653 is 531C main frame and the stays are 753 and the forks are 531. But I then read a post that stated that the main frame is 531 PRO. I understood that 653 was a replacement for 531 PRO?
653 is not 531C at all, although it is the same alloy - it does use 753 stays.
753 is the same alloy as 531 but has a heat treatment (hence the need for silver brazing and the need for builder's licences, otherwise it reverts to 531).
653 uses 753-dimensioned tubes (thinner wall than 531C) but with a lesser treatment. Tony Oliver quotes 653's UTS as 935N/mm2, compared to 753 at 1313N/mm2 and 531 at 802N/mm2. As he was a university material scientist I assume he had access to the data or tested it himself.
https://www.bikeforums.net/classic-vintage/1079768-trying-understand-reynolds-653-a.html
Not necessarily disputing what you say, but I was brought up being told 531SL and it's successor 531 Pro weren't suitable for a heavier rider as it was quite fragile.
I am only 140 lbs, so I hope I am safe on my 531SL frame since I am the second owner.
