bikeworkshop
You might find a nice 25.4 easton ea50 on ebay, they came in several shapes
I'm gonna get a bar with some decent rise so I can adjust reach on the fly, and then I can always lift my stem 10-15mm or so with some spacers that I can just chuck in my bag.Having the option to change your bar position after a few days would be good.
I did one long ride, after a few days wishing my stem was several cm shorter and the bars several cm higher, but didn't have the adjustment.
Maximum adjustment comes from both 1) spacers above and below the stem, and 2) having a multi position bar that can rotate in the stem and bring hand position forward or backwards and up and down.
So I like this type of bars for long distances.
https://www.sjscycles.co.uk/handleb...position-handlebars-254mm-clamp-silver-590mm/
And agree that replacing the brakes with standard V brakes probably a good idea. And I'm very envious of your trip!
Coming along nicelySome detail shots! Gonna go for a proper shakedown today and get the rest of the bike cabled up. It's frustrating that my saddle doesn't match but it's hard to justify the cost of a matching one!
Damn, good spot. Will fix that now! Thanks.Coming along nicely
Just to say your chainring orientation looks out.
The tabs on one space between the mounting arms are meant to line up with the crank - or in this case with the "hidden" bolt opposite :
View attachment 957721so the outer ring is good, but the middle is one arm out - they should be next to each other.
Misalignment upsets the tooth alignment with the chain on shifting, and the position of the cut down teeth and pickup pins - this can cause skating and slipping, as well as poor shifting, it's a common reason for people thinking front indexing is no good![]()
Don't worry, I won't tell anyoneDamn, good spot. Will fix that now! Thanks.
