My first off-roader was a modded (self modded) 10 sod ex-racer which I laced in two 8LS drum brakes I had lying around that originally came of a Bonneville MSS motorcycle - literally overkill stopping power, but the bike was still light enough, steered nicely with a slightly downward bend straight bar and a modified gear selector.
My next was a Peugeot Lion Bike 15 spd, which is entirely forgettable as it was used and very much a rat bike I should have avoided.
After the PLB disaster (all the case hardening on the cogs/chainring was ancient history so rapidly the driveline wore out), I bought a new steel framed Diamondback 21-spd (it was the top of the line, model name escapes my aging grey matter, but NOS when I found it in the bargain buys at the store I started using). My first radio bike, only modded with better tyres (some overkill American off-road items) and a home built holder for either a handheld CB (a Realistic 1003 modded for CEPT and UK FM and to allow a plug in speaker mic) or my Alinco DJ-191 VHF handheld, both using supplied helical so no added antenna mounts used.
Next up, the Univega Alpina 500 SE ‘tank’ which is detailed in a different thread, which became an extreme dual usage mobile/field radio station.
Next up - an alu/cromomy hybrid tubing framed CB MTB (forget which model but was 21spd) that I optimised to build a road/trail/ice mostly road oriented race bike that gradually became another radio bike.
Next up, a very light (seemingly featherweight by bicycle standards) GT frame I somehow ended up with, which ended up with a triple ring crank set (66/44/33) hybrid main drive using parts from the CB (bottom bracket, forks, bar, other mounting hardware), the now very old 8LS drums threaded into 26 inch rims (which seriously complicated the chain angle) using campag spec equivalent rings and a sachs PG/derailleur gear rear hub I brute forced into fitting the rear 8LS drum brake, but the external gear cogs were replaced (with lots of migraine inducing spell attempts) with 8 sod campag cog set. Using a microcontroller and push buttons for triggers, and torque sensing on the cranks (a diy unique setup) you used the chainring and rear derailleurs which were servo activated via up and down push buttons and the torque sensing, via microcontroller and servo activation auto selected the internal PG component of the Sachs hybrid hub - best way to think of is as the road equivalent to CSP on propeller aircraft (where I got the idea from - translating it to a constant speed base ratio control or final drive, depending on how you view it, was literally an exercise that would cause premature hair greying and hair loss back in the 90s). This hybrid street race bike primarily also evolved into a radio bike. Ultimately it was more custom than anything. The CB frame carcass ending up being cut up for tubes for my backyard radio mast.
After a while, as my legs and health started deteriorating, I migrated to a race spec enduro motorcycle which started yet another round of extreme modding and became a go anywhere mobile/field radio bike and commuter rig. The GT hybrid I donated to a neighbour’s kid, less the radios and radio related hardware, but retained the CSP inspired custom driveline setup - which probably raised many eyebrows if it ever got taken into a shop for servicing…..
So whilst the bicycle ownership was checkered, colourful and borderline insane in how I utilised the bicycles, the whole experience was greater than the sum of the parts, taught me a lot about solving problems with an engineering mindset but an experience I wouldn’t change in any part if I could relive the early 90s-early 2K years.
Anyone who claims to never have made a bad mistake is not someone you take advice from, when it comes to buying, as the best of us and the majority of honest ex and current cyclists all dropped a clanger at least once in a buying decision - as with owning any vehicle it goes with the territory. With any luck, when you do drop a piano sized clanger, you can still recover some value even if it’s just spares you’ll maybe use or mod for a different project.
