arrestors -
ye shall be needing proper actuators for those LI's
would thimk the CCCVI to be the right sort of chap
for period accuracy they should show the brass pivot screw, part 359
this part was changed to silver finish about sixty-seven
oy had wunnuh deesa wunza too! :p
IIRC was able to work out that it was the Competition model and in the same livery as your iron
purchased at a drive-in theatre marche des pousses located in San Jose, California back in the mid-LXXX's
it was fitted with Verot Competition cottered steel chainset 55 and Verot 34 bottom bracket, Huret Allvit gear ensemble, Titan stem/bar set, Weinmann centrepull arrestors, Atom 440 pedals, plain saddle pillar
research yielded a birth estimate of MCMLXVII
You can see in the brochure that I posted that the "Competition" was with Campagnolo drivetrain and the "Super Sport" with Allvit.
I would assume the bike was not sold as new in the states
The frame was manufactured by Jonas Øglænd in Sandnes Norway. Allegedly 200 frames were made with 531 tubing.
Parts I have for the Super Sport
Four diffenrent styles of Weinmann from 60s to 80s
arrestors -
View attachment 1001041View attachment 1001042
I have a pair of mod. 68 levers, but for another restoration project.
The serial number for the Monark is 2303505
The p-spring cover cup on the Gran Sport measured 5mm's so it's from late 1953-56
Given that, the fives in the serial and the "55" on the handlebars I would say the bike is from 1955
"Flyg Stål"
"Monark - AB. Cykelfabriken Monark Varberg"
The crown of the monarch
Den Beste Sykkel -
had saved a photo to me HD of one nearly identical to the one owned
when went to post it it would not display
over at bikeforums we had a posting in 2019 of the top of the line example from 1962
it was all Campag Record kitted with Weinmann centrepull brakes
pulled it back up only to discover that the images posted had gone up the chimney
recall it as being an off-white or very light grey/beige colour
https://www.bikeforums.net/classic-...-worth-appraisals/1169608-1962-dbs-value.html
https://www.bikeforums.net/classic-vintage/1171728-dbs.html
http://cykelhobby.com/dbs.html
I have two sets of these waiting for 650b wheel build. These use a proprietary cassette system, either 5 speed with 122mm? axle spacing or 6 speed with 126mm? The freehubs are different length between the speeds and 6s cassette will not fit on the 5s hub. The cassettes are like Shimano UG cassettes but the diameter is a bit smaller. The ratcheting system is build into the hub body not cassette body like on Shimano.
Den Beste Sykkel -
That's a bummer. Would have been nice to see the 1962 model. I've only seen three of those DBS's on the internet.
Saddle quiz.
1. Cinelli Unicanitor, late 60s/early 70s
2. Brooks B5N, 70s?
3. ADGA No.29A, early/late 70s
selle -
the ADGA 28A was the stock equipment on Peugeot models such as A08, U08, AE08 and several others for a long period
name an acronym of founder Anders Gallet
in addition to saddles pillars were also produced (or contract manufactured)
Gallet ADGA saddles advert .webp Satri - Gallet saddle pillar a) .webp Satri - Gallet saddle pillar b) .webp
quilted chappie appears he may be a YFC (Fujita) product -
Fujita : YFC saddles  .webp
