Any idea’s what this is?
lugs -
both Brampton Bros. & NERVEX offered this nozzle cut
it was fairly commonly seen during the interwar period
made by other producers as well
NERVEX offered three patterns of feature cut with this horizontal slot but none are a match for what the cycle wears
head parts -
appear Brampton Bros.
locknut is part Nr. 925 104 or 925 109, depending on thread
adjustable race is part Nr. 915 001, or 915 020, or 915 021, or 915 600
depending upon thread and ball size
head parts offered in three finishes: chrome, nickel, black enamel
dropouts -
distinctive crescent cutout
thought might be Brampton but not shown in my materials
another reader likely to recognise them straightaway
A closer inspection this evening shows that the front hub is Brampton, rear hub says 'H R Pattern'
Front Centre pull brakes are by Phillips
Rear Cantilever is GB Sport Mk II - but is fitted by a bracket that screes down through the the brace which is odd and almost certainly a later addition
Rear freewheel is Villers de Lux
Quite a lot of Phillips 'linked' parts.
So, I'll be looking through old photos of Phillips this evening 😄
shell is interesting in that it exhibits sockets for downtube & seat tube but none for chainstays
wonder if backside made smooth or if it has plugs for chainstays
checked my Brampton materials and no shells of this patern are shown
pedals appear to be Phillips Apollo
Can confirm no sockets for chain stays on the shell... which, I've not seen before...
Bit of an update on this.
I have spent 'a number' of hours searching through 1000's of photos generated by online searches to try an find a match for this bike. I have not found a single match for the head tube lugs and fork crown 😞
Until today. 😄 When I found this on a Path Racer Group over lunch... I almost choked on an olive!
The forks are slightly different on the side, but are the same shape and have the same biplane/truss style crown, they are far more similar than anything else I've found.
The head tube lugs match my bike as do those on the other frame joints.
It also does not have 'sleeves' on the BB shell for the Chainstays like my bike
and it has the same half moon cutout and shape on the rear dropouts as mine does
So what is it? Well the bike above is a 1911 Radior Route Legere.
Obviously pretty much all of the components on mine are different, but the brakes are poorly fitted. If mine is one of these, and is significantly older, it may well have been rebuilt in the 30's or 40's with parts available at the time.... the thick plottens!!
Waddayathink??
Hope she were pitted! 😱
simple eno' matter to check tube diameters and threading to confirm metricalitude
https://forum.tontonvelo.com/viewtopic.php?p=555337&hilit=radior#p555337
firm founded 1904
advert of 1923
J. Chapolard et Goudet, pere et fils
additional pages of this document here:
https://forum.tontonvelo.com/viewtopic.php?p=500563
firm founded 1904
advert of 1923
Thank you for this…. Time for the tape measure!!
