Guinessisgoodforyou
Retro Wizard
80mm Nitto copy.Is that a Nitto type 60mm ?
Non...Finally out of curiosity, is there anything like a more compact brake lever out there ? With shorter hoods ?
ThanksCinelli are 26.4mm from memory. Your bars are almost certainly 25.4mm. As @KermitGKona88 says no short reach levers. Nitto is available in 25.4mm and 26.0mm. As you raise the bars the reach is shortened as hamster said. Try a stem first see how it goes. Edit measure your stem extension and maybe go shorter?
