I did look at the bottom bracket and there are a variety of stamped numbers on it. 231 and 0470 and 6645.Hello. I have a newly acquired track frame. Can anyone identify from the drop outs alone and the other pictures who may of built it or am I asking for a miracle?View attachment 648220View attachment 648221
Thank you!I did look at the bottom bracket and there are a variety of stamped numbers on it. 231 and 0470 and 6645.
I will though try and describe the positioning of the numbers for the mo if that's okay.A photo of the numbers might help, as position, style, layout & in what order can make all the difference
It had never entered my mind that it could be a French bicycle...I just assumed it was British. But I will use that info and look at old Peugeot bicycles to see if I can make any comparisons between the two. Thanks for your reply.From the lugs (and the probably missleadind T.A. cranks): my guess would be Peugeot...
It had never entered my mind that it could be a French bicycle...I just assumed it was British. But I will use that info and look at old Peugeot bicycles for aFrom the lugs (and the probably missleadind T.A. cranks): my guess would be Peugeot...
Believe it or not there is another on the right hand side in this photo 9645 or 0645?It had never entered my mind that it could be a French bicycle...I just assumed it was British. But I will use that info and look at old Peugeot bicycles for a
View attachment 648505View attachment 648506View attachment 648507
