1984 Claud Butler Majestic 2 E-conversion
Bilunt
Claud Butler Fan
Year: 1984 (thanks Peachy)
I’ll work on all this over the coming days—I thought it best to at least make a start. CFF6F8B5-8D02-44D2-991D-8EE3338DBA68.webp 909E6836-DCB2-4426-A5BF-151A6F08BABA.webp FD6B4B59-62C4-49A0-908B-1E1008683D64.webp D479612E-EA02-41C4-A941-E36F02CAD999.webp B0B0896E-05FB-4D37-A0B9-26AD99A0EC59.webp F796B8E4-E726-48AB-BFE1-C0D07ED4BCCE.webp 9FECCC78-5878-46DD-98A2-F532DD15F0B0.webp 21537736-B919-4969-A658-EA21CAD712E9.webp 52102431-D3A2-402B-A544-220972BFD63B.webp 2FAC201F-B28A-49B5-81FB-486C2FD5B648.webp
Frame (frame & forks):
Tubing:
Lugs:
Size:
Frame Without Forks Weight:
Forks Weight:
Headset:
Stem:
Handlebars:
Bar Tape:
Brakes:
Gear levers:
Front Derailleur:
Rear Derailleur:
Cranks:
Chainrings:
Bottom Bracket:
Pedals:
Freewheel:
Cassette:
Chain:
Rims:
Hubs:
Tyres:
Tubulars:
Nipples:
Spokes:
Saddle:
Seatpost:
Seat Bolt:
Bottle Cage:
Mudguards:
Bike Weight (kg):
Other details
Ps, I’ve considered electric for mine, but I was thinking along the lines of a motor hub front wheel like the Swytch kit as you can choose how many spokes you want and they’ll build it.
https://www.swytchbike.com/
I’m not sure how you’ll make a BB unit work with the adjustable cam BB housing? (to get the tandem drive chain tight)
I was advised not to go for a front hub unit as they are apparently the least smooth (in terms of application and management of power) of the three options and can place a lot of stress on the forks. I have been advised to install a rear hub unit but the mid-drive appeals to my sense of adventure. I plan on ordering next week so there'll be updates shortly thereafter, hopefully with some answers.
Here’s the video that made me think it’s doable:
70mm wide on the tandem, so should fit with a bit of messing about (my forte). I also thought of moving the entire drive train to the right-hand side using two gears but it’s just adding to the overall complexity I think.
The place I’m ordering from are quite helpful and they also stock extension cables for all the necessaries, which I believe was a stumbling block for early “converters”.
The 750w motor is also essential as the 1000w doesn’t allow enough clearance for the left-hand gear to be fitted.
P.S. I’m catching up on terminology; piston-rings, camshafts and con-rods are my language up to now. :)
Ah... clever, its got a chain tensioner so doing away with the BB cam housing... yeah that might just work... crack on ;)
My wife’s condition means no more solo riding for me so I’ve decided to take the best bits of my Gary Fisher to make the tandem more comfortable for the both of us.
Wheels, handlebars, front disk and gear assemblies would seem to be an easy swap—unless I’m missing something…
The missus is also less than happy with the height of her seat off the ground (she can barely reach on tippy-toes at the lowest setting) so the 2cm drop resulting from the smaller wheel diameter should help.
2B893BDA-3E0A-4A44-A047-816CBE8CBD8B.webp 3BF56505-AEBB-48E0-B39D-63CB673EA839.webp
View attachment 568801View attachment 568802
Hmmm… calliper lugs…
