konahed":fu0qeycb said:Anyone tried the IceToolz ones?
i used to use more or less the same idea but i wrap it about 7 or 8 times around then cut with pincers [not pliers]nporternz":2wt17o7p said:if you are using pliers then wrap some electrical tape around the cable as tight as you can. Not more than 2 layers though!!!
then cut through electrical tape and it holds cable together. If you cut toward to bottom of the tape (ie leave a minimal amount of tape on the cable) the cable end cap actually fits on over the tape.
job done
legrandefromage":2g4dbs1y said:I found some German 'Piano Power' wire cutters lying in the street - best cutters I've ever had.
