The Broken Parts- help each other repair Thread!
wanted
great idea... :wink:
wanted...
old magura bar lever CLAMP... the old plastic looking type..
bullseye crank.. non drive side arm 170mm i think.. :D will check... lol
Shimano Deore LX Left and Right Hand STi Units - will stick up M# once I've found them
Neither works particulary well, I don't think they would shift well under pressure.........
The LH one has stripped the barrel adjuster too, may be useful for spares.
Would prefer to swap for something useful than just give or chuck away
Looking for
DCD bolts - recessed head top 2 bolts - mine got lost a long time ago
No amount of chainring washers can disguise the reality that the spindle of my Real Design Ti 'crankcase' bottom bracket is bent like a banana. Big ring moves several mm in each direction (even worse with old style 48T rings :().
Hence it's fit only for a singlespeed, or a possible union with my equally bent Mountain LX spider, unless someone out there has a spare spindle (110mm or similar) they would sell/swap?
Edit: I also need a pivot pin for a Paul's Crosstop cantilever - anyone?
anyone have any spare parts lying around for a Paul's Chim Chim brake lever extensions? I have a set that has cracked on one side.
scant":2x3h7jra said:
theboy":2x3h7jra said:
RockiMtn:
as it happens, yes ;)
Ill PM you.
& thats what this thread is all about :)
you're telling! i just threw this out there not expecting to ever get a response, let alone this quickly! :shock:
