So after fixing up my old nickel p7 I found an issue with the frame- om the underside just under the wishbone seat stay, directly above the tyre, I found two hairline cracks in the metal. After poking around a bit I established they went through the metal tubing - not sure what has caused it but perhaps being old and not having a bolt in the underside weld hole might have lead to it getting clogged up with gunk and rusting from inside? I can't be sure though, and the issue appears to only be there after inspecting the rest of the frame.
What are my options for repair here, if any? I have access to a welder (albeit an amatuer one) who can do braze, tig or mig. My first instinct was to seal it with super glue (cowboy!) as I had to ride to work on it a few times... It's been fine so far! I suppose I could also blow out with compressed air and wd40 and them fill with some kind of composite? Or braze a piece of tubing over it as best i can? Are any of these actually good ideas? I'd like to fix it for sentimental reasons. Your ideas please.
