Frame identification help - Marin? two stays on top tube
you mean a taper from round to oval, rather than a sudden bulge. Of so that'll be tange prestige tubing in that era normally.
Yes, tapers from round to oval.
Looking straight on, wider at the bottom. From the side, the profile stays the same - ie straight.
Which Marin frames from 1989 /90 used tange prestige?
Only the Team Issue and Team Marin used Prestige tubing, and they were not the same frame design as the lesser models ie. Pine Mountain downwards.
The pre 90 team bikes had a wishbone chainstay set up.
What is odd about your lovely Team frame is that it is not painted, but nickel coated it would seem. But, Marin never stuck firmly to brochures or year model specs. I guess they had an idea in 1990 to nickel coat frames for next line up, and decided to start them earlier. I've had 1995 bikes with 1994 specs in the past!!
It's a 1990 Team Issue made in Marvel. Enjoy.
Thanks for the information, really useful.
I'm guessing the decals are too new for the frame, looking like 1992 ones?
What would a 1990 team look like?
cheers Bri
