INTENSE M1 REAR BRAKE again
hi, damn this computer, my frame is different to that one, the spacing between the mounting holes is only 15 mm c/c.
cheers drew
Does your frame have the same rear end as this one?
file.php
It looks as if defconfunk (a member on here, who owns or owned this M1) has had an adaptor made up. It looks as if it bolts into the two holes that you mention, and then allows the use of a disc brake with an IS mount..
Might be worth contacting defconfunk?
Hope this helps a bit :D
So I am having no luck whatsoever finding an adapter to fit my M1. I've talked with intense and HOPE , and a couple machinist. Can anyone assist where I may have luck
