Fillet brazed off road adventure bike of unknown origin.
This is the first bike I've owned with a light mount brazed onto the forks and I really want to make use of it. I've got a few different lights, but none that are compatible with it, at least not without a bit of improvisation. My favourite and most used light is a Magicshine which is designed for Garmin handlebar mounts, so that's where I decided to start.
I speculatively bought one of these hoping it would work out of the box...
It can be made to kind of work, by inserting extra rubber strip to fill the cavity, but the clamp is wider than the braze on, it doesn't sit flush with the curve of the fork leg so it's unstable, easy to knock off and even with as much rubber as you can fit, the weight of the light means it would drop downwards after every bump.
My solution was to cut a length of metal tube, file it down so it sits flush with the fork leg, cut a slit and open slightly so it's easy to fit with rubber strip beneath it....
I also applied some helicopter tape around the braze on to protect the paint...
And this is how the Garmin mount looks when fitted, as the clamp is tightened the tubing compresses to a perfect fit which nestles nicely against the fork leg preventing any movement, with the right amount of rubber it won't budge...
Very satisfying to solve that little problem, it's great that the braze on will be used as intended with the added bonus of a decluttered cockpit.
I speculatively bought one of these hoping it would fit...
It can be made to fit, by inserting some extra rubber strips to help it grip more tightly, but the mount is wider than the braze on, it's not flush with the fork and so it's unstable, very easy to knock off and even when tight the weight of the light means it would drop downwards after every bump.
My solution was to cut a length of aluminium tubing, file it down so it sits flush with the fork leg and cut a small section out to make it compressible....
And this is how the Garmin mount looks when fitted, rock solid and won't budge...
That’s a cool fix. I have been thinking about trying something similar to be able to use modern lights.
A few changes to the original plan.
The DX FD is a size too big, but I've got an XT M732. Brakes will be upgraded to M732 with M733 levers.
Also gone for a different wheelset, still DX hubs but on wider Wolber AT-18's.
Yes. But not manufacturer logos unless its identity can be confirmed, which is unlikely.
I've been playing around with making my own decals, so I might put one or two of those on, just to give it an identity.
Why rolf?
“can you tell what it is yet?”
Bit warm for a coat……..
