Show us your 700C ATB / MTB / Hybrid
I unfortunately do not know if they would work for a 27" rim. There might be a specific product to fit that wheel size, but the mavic bridge was made to fit 700c
Ok mate I am right in thinking then if I put one of these on a 26 inch frame front and back I can put 27 inch rims on it do you need to change forks or do 26inch forks have enought clearance cheers
700c wheel should fit in a 26" fork. Will be fine with a smaller road tyre. You probably won't ft a MTB tyre though.
He needs to be sure that the brakes will line up before worrying about tire size. 27 rims and 700 are not the same diameter, the brake post adapter piece he is talking about will need to be 27" specific
If he uses the Mavic piece which he asked about, pads will be off the rim. 27 is 8 mm bigger than 29 somehow?
Glad you pointed that out mate I thought 27 inch were the same as 700 racer wheels I had a feeling I would have to run the skinny MTB tyres so next question is is there another adapter for 700 or is this possible with out changing forks just so I know both scenarios thanks
