What to do in the event of a total blackout: a Revolution!
Well spotted about the cable runs , they are dummy cables at the moment just to see if it works out and it seems to be ok .
The frame was chemically/physically stripped by hand , keeping chemicals well clear of the many bonded parts . It was then
etch primed and wet painted using air drying enamels . Powder coating is not really an option with these as the oven temperatures
reached can seriously degrade the strength of the epoxy adhesive used to bond the seat and down tube panels etc in position
Good tips for painting it
I didn't dare repaint my old one because I don't really know how magnesium behaves with chemicals. Besides, the paint and decals are generally fine, and I like it to be as original as possible (if I can maintain it).
Liquid painting is a great idea. I've personally used this method with the Raleigh Chill and the Sakae Litage, precisely because I was afraid the tubes would come loose in the heat of the oven (I think it's 400º). I also couldn't find a suitable RAL powder coating for the Raleigh.
Oooh. Need to find a pair of those pedals.
I've had them stored away for many years. I have Time on all the bikes I regularly ride.
Even my son uses them (so he can use my bikes too).
This model is really unusual and was from a time when clipless pedals weren't yet widely used, and the other side allowed you to use it safely if you didn't like the cleat system.
Didn't think they would be heavy just noticed as well that the competion yellow frame has all the notches cut out along the top rail and the purple one doesn't yet it has the notches I know it probably weight but it makes it look a lot better
There seem to be several small detail changes to the Kirk frame during it's production life .
1 The 'top tube' ' I ' Beam has potentially five cutouts/windows along it's length . It appears that some versions
only have the rear window/triangle ' open ' and the rest left ' closed ' , While other frames have four windows/slots
' open ' with just the front ' closed ' . Presumably because the front slot is too small to ' open ' easily
2 The cable guides/stop positions are the same for all models , bonded back to back along the top tube with stops also bonded on the
seat tube and seat stay . However the variation is that some frames ( DX ) have all the guides/stops slotted with the rear brake
outer split , while others ( 200GS & 400LX ) have no slots and the rear brake outer is continuous .
Is it possible that the split rear brake outer put too much load on the bonded stops ?
There are seven ' lightening ' holes in a Kirk frame , with a reinforcing rib around each on both sides of the frame .
If there were no holes there would not be a need for any ribs , the material saved from the ribs would ' fill ' the holes !
So there is no appreciable weight saving , I believe this to be pure ' whimsy ' and nothing to do with CAD . Just saying
A great technical contribution to help us better understand these frames!
You've made me stop for a while to look at mine 😄
And I realized I have slotted brake calipers, but my frame was built from a 200 GS...
Would it be logical to think that maybe they opted for a higher-end frame to build this unit because they might have run out of stock of the version you mentioned?
Was 200gs the lowest group?
It's the 200 GS.
In fact, this weekend I didn't feel like working on any bike, so I spent my time sorting through parts and decided to "rescue" some that I was going to throw away, like the Kirk's STI 200 GS levers.
Well, I've found some time to finish this "eye-catching" bike.
Some purple bolts, some Grip Shift decals, and I've decided to replace the saddle with a WTB SST.K, recommended by a friend who told me the white Flite didn't look very good. IMG_5146.webp IMG_5147.webp IMG_5148.webp IMG_5149.webp IMG_5150.webp IMG_5151.webp IMG_5152.webp IMG_5153.webp IMG_5154.webp The truth is that this saddle looks better
I love this bike, I love its color, and it's been a lot of fun to make. I really enjoyed it. I think it's a nice addition to my modest collection.
Looks fab!
I thought from the tread pattern that the front tyre was on backwards, but in fact, according to the Hutch, it's the rear!
Must be because they are French😉
In practice it makes almost no difference, but if it's printed on there, it's wise to obey😁
Looks fab!
Good observation!
It's actually because of the "Rock X Country" branding, which is only visible on one side of the tire, and I really dislike it.
I already mentioned this in my thread about the Look Mi-960, where I indicated that I should change the direction of the tire so that the two logos were on the same side of the bike.
Here I've done the same.
I chose the rear because, in its "official" position, it actually helps you roll faster and with less friction, but in this direction it should have more traction (and more wear :LOL: ). Changing the direction at the front is more delicate; you lose braking and grip in turns.
