Attempting to build up a frame an I need  to swap the shock an retain the old bushes
I can't get them out of the shock body I ve ran a hacksaw blade between the shock body an Bush to create an groove an tried to prise them
Tried turning them with vice grips an warmed it up with a heat gun
What happens if I warm up the shock with a butane torch ?
It's an air shock appears to be sealed no visible valve
Should I drill a hole in it first
Was thinking about cutting it but the part that the bushes go is solid I think
Will try to ad a pic
