27motorhead
- Feedback
- View
I'm surprised the saddle isn't up any taller if you're 171cm tall? Guess you must have short legs after all!Thanks, The paint renovation and clear coat came out much better than I thought it would. A couple of drips in places, but should be able to sort those out. And yes! Good spot!! The front tyre has the wrong rotation, I only noticed when I uploaded the picturesI have since fixed this
I'm just over 5ft 7in too (171cm). I was worried the 18in might be too big, but it's not, and is great to ride, but I do have the seat right down. I think it is to do with proportions, I'm the same height as my brother (who is 5'10'') sitting down...I just have short legs.
A new shifter arrived today, so hopefully will see if that can fix things...
I picked up a 1988 22" Hard Rock the other day to rob the components off it. Clearly it's too big for me as a proper MTB, but I could still ride it fine (with the saddle low!) and it was one seriously comfy ride vs. a typical early 90s machine with your head down and arse up position.
Leave the clear coat/lacquer for as long as possible to harden properly to enable you to cut-back the drips cleanly. Good luck with the new shifter!
