Funk A.S.F; another unicorn…
The lower pivot is quite a bit smaller than on Ristonesia's. You have to wonder which was made first - another question for Mr. Funk!
Interestingly, the pivot pins on this frame are different as well. The provenance of the yellow ASF is known, so I’m guessing that it predates the blue one as they seem to be the same as on the frame featured in the MBA article. 162ABEF3-5A3C-4AF8-B0FC-CB21BCF6F856.jpeg 93B6333C-1B48-452E-9643-04607DDA00FF.jpeg
Just one question, this isn’t really related to the bike, what are the thinner peices of outer casing called? Because I can’t find anything about them?
This funk looks really good never seen one that looks like this!
Outer casing on the brake/gear cables?
You could always try some internal tubing that’s used on a Klein - if you don’t mind clear/white, then Jon Rock sells it.
The bank fees were more than I’d anticipated, so in order to keep the costs down I’m hatching a new plan… The box should be on its way to Jakarta next week but don’t expect any updates for a while! 92C2A957-9A06-49F3-B60D-B0A6310CF31F.webp
