Thoughts pls - is suspension travel too long?
I guess the seat tube is pretty slack so that could stuff things up, especially if the rear triangle is short?
The bike is floppy and wobbly and dangerous with these long travel forks - unrideable
70mm forks were perfect - but I’ve a chance to swap with some 80mm travel Quake Air but if that’s going to give me the same result as the 100 then I’ll be in trouble again
You can switch the forks to 80mm travel looking at the manual.
Could try that.
I had no idea they were adjustable - only manual I found shows how to adjust air and dampening - can’t find anything which shows how to adjust travel. @xtaffa offered me a swap for his Quake Air so let’s hope he’s happy with the axle to crown measurements !
