D
Deleted member 72370
Hi all,
My beloved 1996 Trek Y11 has seen some better days. I’m told by the bike shop that the bushing at the unified rear triangle pivot point that connects to the carbon Y frame is cracked. As such, whenever I pedal hard or force down on the cranks, there are loud cracking sounds that echo through the frame. Fairly disconcerting.
As well, the rear shock recently died on it, and seems to no longer have any pressure. I’ve since resorted to just tightening the coil as much as I can to try to effectively lock it out, but I’d rather replace the shock with something cheap and decent. I’m not sure what a good option may be? Not sure sizing etc. The current shock is a Rockshox Vanilla of some sort. Unsure if it matters but the frame is a large.
I’m hoping someone may have an idea about replacing this bushing or whatever would be causing that cracking sound at the pivot point, and where I may be able to track down the part. I’m coming up empty handed so far.
Thanks for any guidance!
