1995 Claud Butler Titanius Campagnolo gravel job FINISHED
they have indeed. Those hoods look a long way forward by the way. Can you reach them?
Tbh the frame is a little on the small size for me hence the long seat post. I found the position of the hooded to be fine, but then I was just balancing on it rather than riding.
I guess the proof will be in the riding, but as I’m building this as a fun “lunchtime blitz” bike which will live at work and only get used for 20 minutes at a time just as an escape from the mind numbing tedium, I’m not sure I’ll ever really need to worry too much…
I ain’ts buying nuffing… Mrs Peachy wants a holiday
are handlebars not considered to be consumables?
Ah ha!
The local “Cabbage run” has been turned over to Barley, something to do with “crop rotation in the 14th century was considerably more widespread after….” (Answers on a postcard please)
But…. The next field is now the “Sprout run” half a mile of super smooth straight downhill 😁 (mostly hidden from view) when you hit this rise 100yds from the end, you need to throw the anchors over board! If you get it right you can sweep through Deadman’s curve, if you don’t it’s into the chalk stream you go….
Definitely the TightAnus’s virgin run! 😬
D29C22D1-351E-448C-893C-839EE7097A61.jpeg 4AF4CC84-98C3-4A58-8DB9-62A746FFAE50.jpeg AE337200-5AD8-4FB0-B5E2-B8286FCF45E5.jpeg
I've plastic nut and bolt containers eerily similar to yours, but being in the USA the containers are...round!
