I hope it corners better than your hose reel.
Top job as always.
would be more aero with a smaller frontage…………..
Top job as always.
Mrs Peachy is in command of all garden vehicles...
Sorry, wrong *OZ...
Thanks to @Woz for the rocker suggestion for the Canti’s. It worked brilliantly for the front and I also used a set for the back as the clamp bolt hanger was all a bit too cramped for my liking..
:) Foz / Woz ..... we are both Wizards....
Pleasure to be of help. To be critical, from the pictures at least, I reckon you have a little more tweaking to do. Ideally of course,
you want roughly equal length L & R inner cable exposed so the rocker is settled like a V. Getting them to hit the rim at the
same may involve putting the canti-springs in different tension holes in the bosses. Otherwise, for sure they are a great
piece of kit to get you out of some sticky build situations.
Looking very good, no doubt it will be a lot of fun riding. I reckon you have hit a nice sweet spot in modernising and keeping the old.
Cheers Woz, unfortunately the mounts only have one hole for the springs so I couldn’t tension one side harder than the other, I did try the adjuster screw but that wasn’t strong enough. I’m afraid how it’s currently set willl have to do. They do work very well.
  • Like
Reactions: Woz
Brilliant build!
Cheers. I’m itching to ride it properly, but the lads under strict orders to revise as it’s internal exam week at his school!
Mrs Peachy wants a go, but has asked for a “ladies” saddle.. I’d picked up a grey suede Specialized flag cheap on eBay. Usually quality, never been cleaned, just screaming out for some Peachy TLC... 02B11FC3-D237-4385-8434-178FAEDBDAE8.webp FEC70A6E-E27B-4DD2-89C2-C7DEF57ED060.webp 3538156C-6213-4BCE-87EE-460BA89C27F5.webp
Pristine . Consistency is a measure of tastiness .
Commenting on your work seems kind of redundant . Hats off .
