8.[Temperature-differential method, which is applicable to any seatpost material: Buy dry ice (solid carbon dioxide, which melts at -78.5° C (- 108° F). If you have access to laboratory supplies, you might also use liquid nitrogen, which is even colder, though its cooling effect is not as great because it boils, forming a shield of gas around itself. Ordinary water ice also might work. Remove the bottom-bracket parts, cork the top of the seatpost if it is open, and with the frame upside-down and a saddle attached to the seatpost, drop chips of (dry) ice or pour liquid nitrogen down the seat tube into the seatpost. Then hold the saddle down on the floor with your feet and twist the frame. You may also warm the seat tube by pouring hot water onto its outside. Wear winter gloves, and socks. Do not touch dry ice, the seatpost or other parts chilled by dry ice or liquid nitrogen. I thank John Newgard for this suggestion. Sheldon's original suggestion follows -- John Allen]
If nothing else works to free up a steel or titanium seatpost, the next-to-last resort is to heat the seat tube up with a hair dryer or propane torch. This should be done with great care so as not to do too much damage to the paint. You should work as fast as you safely can, because you want to heat the seat tube so that it will expand, but if possible you should quickly put the torch down and start pulling on the saddle before the heat works its way through the seat tube and makes the seatpost expand too.
