Rockshox Mag 20 and 21 Air Valve Caps
I'm still using my personal stash.
Stubby Valve - google bring up all sorts, but I'm guessing it's not the mains pipe looking things but the tubeless valve type things.
I think one of the valves from my MAG SL/Ti is leaking. I serviced the fork together with another MAG SL/Ti and a MAG21 from '93 a few days ago. The other SL/Ti and the MAG21 are working fine and hold the air, while the other SL/Ti loses airpressure much too fast. So I think of rebuilding the valve caps, but I don´t know from where I can get the rubber from within the valve.
When you do the MAG Service, do you replace the rubber from within the valve caps?
Easy way to check is put the leg to 100 psi and in a sink.
Or switch caps.
I can replace the valve bung, need to find my stuff as packed most of it up.
