- Feedback
- View
Getting really cheesed off with the downward quality of parts now from motor factors and parts suppliers. Apart from getting my order wrong every time, this time sending me a clutch release bearing for a Transit rather than a Peugeot 205, but parts that break or cause other problems.
This time a water pump, initial impression was why has is got 6 blades instead of the old 8 and why only 3 intake holes instead of 4, no matter i'm sure it'll be fine. Go to fit and the holes don't quite line up which means getting the last bolt in a bit fiddly, but in it goes. Then down to tightening the last bolt and the head clean snaps off :evil:
Have another look at the pump flange and it's significantly thinner than the old which means the bolts are going in further into the block! And in this case hitting the end FFS!! Now i've got a right pain in the arse job to do just because some company wanted to save a few pennies on materials!
The number of crap parts i've had recently, hand brake cables that arrive ready split, exhausts that haven't been fully welded and I had one that blew the silencer inside out. Driveshafts that last 10k miles, starters that last a year, head gaskets that won't seal, list is endless. I used to buy OEM from the dealers for everything when I could afford it, but i'm certainly not buying the cheapest parts now, just bog standards replacement parts.
Rant over, not looking forward to getting that bolt out.
