M730 crank caps & other XT M095 small parts
Updated wanted list!
UN 71 (or higher) 68x122.5mm BB
Zoom 130 bars, silver/alloy colour
Bontrager BCX1 & BCX2 32h rims
XT M730 F hub
XT M732 R hub
XT M730 crank caps in silver
zoom bars
ventured into the garage, they are black zoom 155 cut to 50cm, however also found silver Xlite Cross country, also slightly angled at 54 cm and a Xlite titanium straight bar at 54cm
any use
Re: zoom bars
any use
Zoom's are a bit too short for my liking, thanks for measuring them though.
I currently have a pair of Amoeba Titanium bars on the KHS and would like to return it to as near as possible to original spec, which are Zoom 130's (although a very similar Zoom would do)
Wish I had another project for those X-Lite Ti bars :(
Updated list of parts required for my '93 KHS
Two XT M730 crank caps in silver
One XT M095 shifter cable port cover
One XT M095 barrel adjuster lockring
port cover : Is that Part 3 ?
Might have the second thing as well (ring on Part 6)
Part 3 do go missing quite easily, if I find it you can have it. Finding it will be hard though :(
I can pinch 6 another shimano lever I think ;)
What hubs did you get ?
Parts 3, 6 and I forgot part 5!
Yeah those little port covers are buggers I swear I had both a week or two ago, one is now AWOL!
If you could find one that'd be cool, don't worry if you can't find one though
Part 6, I only need the lockring, I wondered if any other Shimano ones would fit as they're quite chunky
Part 5, the rubber covers, I could take or leave, but seen as I'm trying to get it as close to catalogue spec I'd better get some, even though they seem to be as rare as hens teeth
I have the correct hubs coming, M730 & M732 with Mavic CD231 rims, I suspect the OE spec Bontrager BCX 1 & BCX 2 rims will be seriously hard to find, along the lines of Unicorn poo in rarity
Hey there Andy, something jogged my memory and here it is.. I just found this link I remembered seeing for some BCX wheels, it's a bit old and a long shot but you never know:
http://www.retrobike.co.uk/forum/viewto ... hlight=bcx
Failing that, you could try searcing for a cheap 93' kona that can be parted out as all had BCX rims of some description fitted...they were made to be pretty light so I guess most wore out with use and ended up being melted into coke cans :(
Anyways, good luck!
Either KHS Ginner or paininthe had some Bonty rims, Could have been BCX3's though.
Though the 231's are much better rims.
Ginners KHS has BCX3 rims on it, I have a pair too on Exage hubs. I would stick with the Mavics if I were you.
