Wanted Hope Pro 2/4 Front Bearing spacer or Hope Pro 2/4 HUB
chodjinn
I'm looking for the front bearings spacer for a Hope Pro 2/4 hub, the 20mm metal sleeve part and 3mm o-ring.
Alternatively I'll take an entire hub, as long as it is black 32h. I already have the 20mm conversion kit. Ideally a cheap one!
I've got a hope 20mm hub doing nothing. Was going to convert it to 15mm. Might a swap be an option?
I actually have a set of 15mm converters mate, but it depends what hub yours is? Also depends on what bits you might be after...i have a box of random stuff hah
Here's a few pics of the hub I have. It's in vgc, bearings good and only a small scuff on the 20mm axle mount on one side to speak of.
