Frantuzzi (was Intense Uzzi VP 2009)
As I mentioned before, I wouldn’t mind shorter chainstays and a longer reach, but I’m absolutely thrilled with how the VPP works. It performs beautifully — it’s sensitive, hardly bobs while pedaling, and behaves great under braking. Already in the spring, when Franta Mrázek was making me a trials frame, I arranged with him that in the fall I’d bring him the Uzzi, and using the existing linkages he’d make a new front and rear triangle. A week ago, I gave him the frame with the shock and added a sketch. The frame design is just my own estimate — Franta will make it as he sees fit. But the shock mount sits quite precisely between the top and down tube, so it’s not really possible to use a classic design. The frame should be finished around the end of January.
By then, I need to buy a headset (the Uzzi uses a 56 mm head tube), and I’d also like to get new brakes. My Hopes once again, after three years, won’t bleed properly — they probably need to be reseals — but since the rear brake hose would definitely be too short anyway, I’ll just buy something new.
I know this is retrobike but if you want modern numbers and like the vpp platform then why not spend the money on a Tracer or if you don't need the travel then maybe a Sniper? I love mine
Buying a commonly available bike would certainly be more straightforward — though probably one a few years old, since finding a bike with a 75° seat angle these days isn’t that easy, and I don’t want a more upright one (I’d probably be aiming for something like a Primer 275). But I have several reasons for choosing this solution:
1) Financial aspect. Franta Mrázek welds frames really cheaply.
2) Steel. I just like it — for its looks, durability, and the possibility of later modifications.
3) Freedom of geometry atc. I can come up with almost anything I want. Sure, Franta has his own ideas and sometimes handles certain construction details differently than I imagined, but everything always works perfectly.
4) History and personal connection. He welded my first frame back in 2005, and I’ve had a soft spot for his frames. It probably also has something to do with the kind of person Franta is. For me, it’s in a way an honor to ride his frames.
