svenskaaeroplanaktigborg -
appears/sounds like you have the necessary kitting pretty well in order now
hast thee made any decision regarding transfers?
leave them be as they are?
look into making replicas?
other?
Huret -
doth Sasaki make any mention of an iteration of the Super Touring with articulated pulley plates?
recall seeing such a beast in the parts bin of a LBS in 1972
possible it may have been fabricated by an enthusiast as a means of creating additional chain wrap
instead of two plates there were four connected via a rivet or hinge mechanism and sprung so that they folded up upon each other when relaxed
saw no indication of such a model either at disraeli or amongst the catalogues found
am quite aged so possible this may be the faulty "memory" of an elderly geezer...
other?
Still need to find seatpost, old M7 bolts for the chainrings and brake levers.
I don't really see the value in full visual restorations, maybe if the bike was in really bad shape and/or really rare one, but on this all the decals are good considering it has been used "daily" for over 60 years and is now 70 years old.
I still haven't washed it from all the dust accumulated over the years it sat in the storage so maybe it looks worse in the pictures.
If I did the paint and transfers then I would need to get crank that's in better condition, 50's wheel set for sew-ups etc.
With original paint and deacals I think the bike "tells" a better story with all the scars and marks.
My goal is usually to make it ridable and get the catalog correct components or period correct if they are better or at more reasonable price.
Huret -
I don't actually own the books, but I would love to. I found a German online store that sells them, so I maybe get one or two at some point.
Really!? This one?
"US application filed December 1970, French application filed March 1970"
The patent for Huret Duopar was applied in '73.
Source: https://www.disraeligears.co.uk/site/us_patent_3677103_-_huret.html
us_patent_3677103_-_huret_parallelogram_scan_2_main_image.webp us_patent_3677103_-_huret_parallelogram_scan_3_main_image.webp
Thank you!
Yes, the mech I saw all those years ago looked more like the drawing in the patent record you posted than like the production Duopar with which we are all familiar.
Reassuring to learn me "memory" was not making it up! :D
Shall look forward to seeing Herr 303 whenever he is completed. ;)👍
Thank you!
I have another project that's been waiting to have the proper parts that I'll try to finish first.
Here's a few clues.
Love this. There's like "cobbled together" but it is not "cobbled together". On the functioning limit. 🥰 Lovely build.
Thanks, it's a bit rough the frame, and the rear fender line is awful.
Getting the right fit is always a challange. I'm about 186cm with 86-87cm inseam and this frame is 57cm c-c? Anyway I lowered the seat post a few cm from what it was in the picture.
The 180deg. lever throw on the FD is too much so I will take the triple TA rings off and put the Stronglight 49d rings that came with the crank back on there. Weirdly both front and rear shift really well. The chain is old Sedis chain that was under 0.75% of wear and the freewheel is Atom with the "S.G.D.G." stamped on, so made before 1968?
Only thing is that because of the round lower pulley the chain moves around more and rubs on the pulley cage. I aligned the hanger and chainline is good, but on large-large it starts to make itself heard.
Here's a few clues.
View attachment 1009630View attachment 1009631View attachment 1009632View attachment 1009633
pre-mcmlxvii
oytoy w/qlty plain gauge tubing...Falck?
possible temporal conflict betwixt Fratelli Pietra cccvi's and chainset
for this date pivot screw (part nr. 359) should be ottone
Freres Huret addendum(b) -
recalled that mech seen in bin at LBS had been seriously torsioned (pretzelated!)
recall being struck at how spindly and vulnerable looking it was, a victim of some form of misadventure
t'was in a bin o' deceased mechs which were being retained against possible ricambi cannibalisation
