Same here if I just wanted it "built" but it will be a bit of a slow process as I'm still deciding what kit I'm definitely going for.I could finish it this evening if I had the time to do so...
but finishing it to the spec I have planned however, that's a different story
Yours is coming along nicely, doing a build thread for it?
@Dr-Zocchi I’ve got your rebuild kit book-marked, just no funds at present.Check the top air plugs under the plastic top caps. If you see corrosion it needs some special treatment. Also check stanchions.
But all in all this forks can be rebuild as it best and we have all parts & spares to do the job perfect - including stickers.
I have the advantage that classic Giants aren't highly valued in Spain, not even the Cadex ones. Much less so are full carbon frames, so even though there are few, they're cheap.
Yes.@Dr-Zocchi I’ve got your rebuild kit book-marked, just no funds at present.
Stanchions are in lovely condition, one top plug is spotless, the other less so - what sort of special treatment do you mean? Perhaps I can pm you with some close up pics for your appraisal?
