Chris king headset
baron von greenback
What frames need the grove putting into a ck headset ie pace f2 now is it for the reason someone said it releaves the pressure on headtubes that are prone to cracking by 35% and thats the main reason as say some frames having a notch in so a ck wont fit (example dont know if true) and can i just fit a ck to pace f2 (or other frames) without issue except it might crack and why is it only ck headset need this doing
I'm not sure if fancy cutting a headset. Crown race yes.
If a headset tends to work in most frames but can cause failure in others, not sure if blame the headset, though the design of the Christmas king using the rubber o-ring to grip the steerer tube over the compression style could allow movement and stress the head tube. Maybe? I'm no engineer.
I had a king on a pace with a 1 inch steerer and it did not crack. Not saying it won't as there seems to be examples.
I've never heard this, is this a thing people do? In such an application I'd simply find something that fits and do it right. Or you could end up with;
Ruined frame
Ruined headset
Ruined face/teeth/hands etc
Or a combination of any of those.
Read the post from Danson who is far better than me at explaining it
King headsets are slightly larger than many others.
This increases the risk of cracking the head tube, specially in a 30 year old frame.
Not much though.
8 years on here and I've never seen or heard this, just accepted that some are tighter than others and that's that. That groove must be shallow though? I wouldn't want to put a CK cup in my lathe and mess it up.
I do have a Chris King, but in a Soul 😊
I’ve had one of these put into my CK by Danson (on @d8mok advice) ready to go into my Kona Ku frame (which we all know are prone to cracking) 😬
I’m actually planning on installing it today, it is the 98/99 model though with the headtube flares so I’m confident it will ok!
Please report back with some photos of the process and end result.
