Englund air cartridge parts sequence for Judy’s
mugly
I’m rebuilding a set of Judy FSX’s with a pair of Englund cartridges.
I’m having a senior moment for the correct parts sequence for the lower shafts.
I’m aware i appear to be missing a couple of parts…possibly a spacer under the end of the cartridge which sits on top of the lower shaft (would a standard judy top damper plastic spacer work? and a nylon/rubber spacer under the burgundy part that sits in the lower part of the stanchions held in by the circlip)
Anything similar i could use and if so i’m guessing an ID to match the lower thin shaft so it’s not flopping about?
So they came out as the 1st pic (let’s go left to right as 1/2/3) I did a dry build as they came apart and seemed to work fine but i’m probably over analysing now so which is correct.
Any help is muchos appreciated
I fitted a set of these to an fsx a long time ago. Wish I still had them tbh.
I have a nos set of these allegedly for a 98 Sid, I could open the packet a d see if they are the same and send you a pic of the manual.
And a thread on here with the manual.
if you wouldn’t mind, i’ve seen the seal kits already and the basic 2 page instructions on setup but doesn’t really give me the info i need.
I have 5 or 6 sets, without pulling them apart and from memory, pic 1 is correct (left side)
They are missing a thin "buffer" that goes between the bottom of the air shaft and the solid alloy tube with the spring on it, it's literally a thin bit of rubber if memory serves.
I think you’re right, found a couple of pictures eventually of forks taken apart.
I have some thin nylon washers on order to take up the space around the burgundy part and added some rubber stops on the end of the cartridge lower rods so hopefully they’ll be up and running by the end of the week.
