Arrived today. Everything matches the image above, no missing parts.
First impressions:
The lamps are incredibly lightweight, no doubt due to cheap plastic construction.
The cable for the front lamp is much shorter than the rear, so this would be best set up with the dynamo on the front wheel.
The dynamo feels solid and the wheel rotates freely and smoothly. The angle mechanism has a satisfying click to it.
Fittings are all nice, threads are well cut and brackets have smooth edges.
Cyrillic text on the casing confirms Russian or Soviet origins. Anyone familiar with that period will know that the soviets tended to make things cheaply, but with robustness and serviceability at the fore. Their stuff is famous for being simple to maintain and easy to repair, but equally notorious for requiring regular maintenance and repairs.
Products often suffered from inconsistent manufacturing standards, with quality of assembly and workmanship varying wildly from factory to factory.
Be interesting to see how this functions, I'll update the thread once fitted and tested.
