Hi, Thanks you like my story on PROFLEXTHESIS. Yes you will see a number of my pic's on a couple of Proflexes fitted with discs. There was known actually made by Proflex or K2 themselves. All done privately with others equally obsessed.....Thanks for all that info on Proflex! I also am obsessed with them. I have seven of them........I know I'm a HOARDER but I can't resist a deal when ever it comes my way. Here's my list 755,855,856,[2]656,beast& a 656x which I believe is a prototype because it has front & rear disc brakes. The X I took as experimental? It's the only one I ever seen with discs. Your feedback would be appriecated. Thanks
Thanks, I've attached my own Proflex 'Family'. (left to right) my K2 Proflex 4000 -is tremendous with the K2SmartShock (electronics - make it the magic carpet) on the fronts when on the cobbles and very rough stone, next the 857 - brilliant on any trail, then the 757 with Risse Astro5 - at rear - brilliant for fast up hills, then the 656 with the elastomers front and rear stripped (as very poor) and fitted with to Landrover Defender Suspension Bushes which are so much better (Fit 4 x Ref BEARMACH BR 0695). Regards All......Nice info up to now mate ( only read part 1 up to now) some nice bike always wanted one i never seen a bike with the eletronic shock on them also i got a set of girvin forks black wirh yellow stickers if i need some advice when fitting alright to send you a txt cheers off to read part 2
