BMW Super-Tech FS 1997 – Need Front + Rear Suspension parts (serial 038503)
Geom
Hi everyone,
I recently acquired a BMW Super-Tech FS frame (serial 038503). Unfortunately, both the **front suspension fork** and the **rear shock** are missing.
I'd really appreciate any info on:
– What forks originally came with this model?
– Specs for the rear shock (eye-to-eye length, mounting hardware)?
– If anyone has parts for sale or knows where to find them.
Also, if aftermarket solutions are possible (e.g. compatible rear shocks or forks), I'd be happy with that too.
Not sure if this helps but previous owner of this may be able to help?
And here with different shocks.
You might be able to get away with a trunnion mount shock on the front due to the mounting point, no idea what i2i or size you'd need at either end though. Older trunnion shocks I know of are rock shox deluxe (coil) and you could match with a standard coil on the rear, similarly air shocks from fox and manitou, risse as well.
Mounting hardware would really depend on the shock.
Thanks for the reply .
I will check it out
