winjohn
I have an M Steel touring frame with a 68mm BB shell that I am intending to put a Sugino triple crank on. I had an Ultegra Hollowtech set up on it but decided to go back to a more period correct set up with a wider range. I had a look in my BB box and slotted in a 68x103 since it was the only suitable one I had. With this installed with the Sugino cranks the inner ring just contacts the chainstay. So clearly I need a longer spindle length but what length would be best?
My simple brain says that adding 10mm and installing a 113mm BB would give me 5mm clearance but then I am wondering if I should be considering Q factor and chainline too. But will I need to fit the BB first and tighten down the cranks before I can check that?
Any thoughts or suggestions would be welcome.
