Asian "Brooks" saddle modification
Jesper
I got thus unused fake "Brooks" style saddle in a bike deal (read as: guy cleaning out garage giving away free stuff) years ago; including a real B.17 which was barely used.
This saddle unfortunately had/has a couple issues (why I do not buy them) both from the factory and made by the previous owner.
Factory issues with these is usually with the saddle not being properly aligned; leather cover not evenly cut/shaped, mounted or inconsistent thickness; rails not straight or spacing consistent; etc. On this one the spacing is fairly decent only being 1mm (Brooks ~.75mm) difference front to back, but the rails are not straight which can stress clamp pieces/channels, and make it noisy when riding. I can fix that without much effort, but you should not have to do that with any quality built saddle. The cover is 1mm thicker on one side than the other, was cut unevenly at the cantle, and was also shaped over the plate partially covering bag loop access. Saddle alignment is 9 out 10, not really noticeable and will not affect actual ride.
The last owner had already cut back the side skirts (I assume in an attempt to make a "Swallow" style) leaving one tab per side. Neither side was cut particularly well and mismatched to the point where the front section of the rails were partially exposed on one side and completely obscurred on the other.
I evened out the poor lines, fully exposed the rails and bag loops (dropped ~25g not inclding whatever was dropped after initial modification).
I still have some final trimming left to clean up the lines and curves (being anal!), round off & punch aux. holes in tabs, chamfer (or "hand-skive" as Brooks likes to say) and buff the edges, enlarge and add grommets to bag loops, and add proper tab binder; but essentially it will look as seen here and is a prime candidate for present project (Vianelli built Gandolfi) to give it a classic, but sleek look befitting an early to mid '80s racer. Weight ~530g, 16.5cm x 28.25cm x 7cm
It's been almost 2 decades since I've done any leatherwork, so not exactly fresh terminology and things might have changed, but "skiving" is a term for thinning down leather, either reducing the thickness of the whole sheet (say, 5mm to 3mm) or feathering out the edges (Say, 4mm to 1mm over the last inch from the edge). I don't think there's any need/much room for skiving here.
"Chamfering" is called "edging" or "bevelling".
So I wonder what Brooks marketing guys are talking about when they say "Hand-skived" ;).
PS Not a fan of Brooks saddles. They make the best artificial leather bar tape, but saddles-wise I'd rather perch my butt on a Leper.
finally, someone on here who talks sense about brooks saddles. Whilst I'll let you ride the leper I would rather not ride the brooks thanks.
It has nothing to do with "sense"; but instead personal preference. If it had to do with "sense" as you use the term, you would be calling everyone who rides around in comfort on a Brooks saddle senseless which of course is false. Those folks personally prefer to use the saddle of their choice (other than stock rebuilds/restorations) because they like how it feels; the same way I assume anyone buying their own saddle would do. Of course, I have been uncomfortable on some Brooks saddles and comfortable on others; but I have had the same experierience when using multiple saddles of the same brand also. I just use common sense and ride what feels good without brand bias regardless of what another says (unless regarding durability/general build quality) because my body and riding posture create a unique form that where I might be comfortable on a saddle, and where another is not.
I know that I personally prefer not to pay the prices of new Brooks saddles (and I do not); but I could say that of many saddle brands which is probably why I have not purchased a new saddle (San Marco Rolls; still being used) to replace an old saddle (Brooks Pro, but not broken in by me thus ergonomics no good for my anatomy) in 40 years.
I personally prefer some Brooks models over others that I would not ride after having ridden on them at least once; but I could say that for every brand I've tried. I personally prefer a slightly used Brooks saddle (and though I've never bought one new, I've received some new on bikes) over a new one; and even Brooks advertises (and thus admits) their main (leather models) disadvantage because they sell "pre-softened" models saying something like comfortable from day one ehicheans their other new saddles are uncomfortable at least until day 2. Rather ironic for a company saying how comfortable their saddles ARE and nof will be. Tron & Berthet did tje same thing decades earlier with "Rebour" treatment models.
Anyways, I hope everyone enjoys riding on their saddle of choice regardless of brand, style, price, etc.; and if you do for some reason ride on a saddle that you are uncomfortable on, well that would certainly seem to be senseless to me, but for some pain is pleasure (new "Hellraiser" saddles available now).
@M_Chavez I come from carpentry/woodworking and the term skiving was never used, but chamfer and bevel are 2 different edge finishes; definitely will not be bevelling the leather in that respect. What Brooks stated as skived is what you describe as "feathering". Brooks "skives" about 10mm up the side and 2mm thinning on 4mm thick leather. I am not doing that much (maybe 3-4 mm up the side and 1-2mm of thinning on 5mm thick); but it needs to be done if you could feel those edges and how the leather sits once my weight alters the shape. Pluscit will look better and it makes it easy to dye a narrow band around it and provide a bit of class on an otherwise basic leather saddle.
