1:4 scale Ritchey P20, this is going to take a while...
Very clever mate and skillful them trophies were good you wouldn't think the work that goes into them the stickers that you use are they water applied decals can you replicate them for full bikes decals what machine would you use are they expensive or can you do them for sale cheers
Thanks Greenback.
They're waterslide transfers. You can get the paper for them off eBay for a few quid, and print them using any desktop printer.
This is the stuff I used: https://www.ebay.co.uk/itm/232322269621?var=531574309332
Then all you need is a quick covering of spray varnish/lacquer to seal the ink before you wet them. I'm not sure whether they'd be any good for a bike. They'd definitely need a good strong coat of clear lacquer over them as they can be quite fragile. Depending on the printer, they might fade in sunlight. Not sure, 2D is not really my area of expertise.
If you're after some decals doing, the member GilM on here seems to be everyone's go-to guy.
Those trophies are bloody amazing. On another level compared to the trophies i used to get when i was time trialling. A bit of wood that was shield shaped with a wonky organising club badge and a badly cut plaque with spelling mistakes was the norm 😆
Thanks Frankenorange.
This is what happens when you ask a model maker who is into bikes to make bike trophies.
The event was organised by a good friend of mine, so I got a bit carried away to help make sure the weekend was a success.
Thanks Greenback.
will work just fine on a bike frame, but put them under the clear coat if you want them to last.
Ok mate that's great now I haven't got a clue about computers so I assume I need some software and how do I get the designs for the decals to print or can I find a pic on the internet and transfer this to the printer or software bear with me haha thanks
