Steerer size
The crown is the big alloy bit the steerer sticks out from. Iirc on most manitous the steerer is pressed in so you need to replace the crown and steerer rather than just the steerer which was possible on some older forks.
You can get headsets that take a 1 1/4 to 1 1/8 or shim the frame and run 1 1/8 headset.
