Seen this £40 posted bit more then I wanted to spend tbh hoping one unused going cheaper but really appreciate the share
 I went down that SJS expensive route, I mean, you never know when you might decide to fit Royce bottom brackets to all your bikes
 I went down that SJS expensive route, I mean, you never know when you might decide to fit Royce bottom brackets to all your bikesI went down that SJS expensive route, I mean, you never know when you might decide to fit Royce bottom brackets to all your bikes
I’m planning on fitting it to a Dave Yates built Condor to run a triple crankset, I should really stop being so tight fisted but I thought it was worth seeing if one out there unused before splashing the cash.I went down that SJS expensive route, I mean, you never know when you might decide to fit Royce bottom brackets to all your bikes
London but it would be handy to have one as I need to swap it out of a frame which I want to sell before fitting it at a later date into the Condor. Will prob buy one on Friday if no luck on here.Where are you based?
Someone local may have one to lend
I have one in Greenwich if you want to go 5he borrowing route. Can’t sell it as I have them fitted.
