Early Bontrager Race Lite
1x10 or 3x8
  • Total voters
    7
  • Poll closed .
You have to remember that a suspension fork will sag.
A standard (non LT) Mag 21 is about 406 mm. 20% of your massive 46mm of travel in sag brings it down to a ride height of 397mmish or about the same length as the Comp fork. šŸ‘ 😁
A indy c with 63mm travel has a A/C of apx 420mm - minus 13mm for the sag gives 407mm. But same same
The issues is the rake - 14mm makes a difference in how the bike feels, but it might not be a problem. I have only experimented whit it on modern mountainbikes. The pike fork comes in different rakes, i think 35mm and 45mm, the extra rake gives a more slack front.
A rule of thumb I use, approx:
410mm for 51mm - 63mm travel.
420mm for 63mm - 80mm travel.
440mm for 80mm - 100mm travel.
The thing with bontragers is that they are designed around a fork with lower rake then normal, 1.25ā€ (31,7mm) - it might be hard to find one if it’s not a bonty, most rigid mtb forks have a rake around 45mm
@keith_bontrager do you have the spec on the rigid privateer forks? Do thy also have the lower rake?
As I recall the forks on the Privateers were built with the 1.25 offset. The difference was the crown, the rest of the fork was identical. The early Rockshox crowns with 1.25ā€ offset were anodized black.
Either offset is fine on the trail.
