I did have 42 earlier in the year and I discovered the meaning of life was to divest as one gets older.IF one had 42 you would discover the meaning of life.
Reaches for the pan galactic gargle blaster
Later today when I have put them all back to bed I will take a photo. They are mostly out sunning themselves at the moment.Show me howplease
If you have ever worked for a large organisation you will know that an "audit" is generally carried out to give the illusion of doing something about a perceived issue while actually it is just a performance that leads to very little change while serving its main objective in placating the naysayers.Audit Audit.....Audit .....somebody call the mods , this post is bang out of order,,,l,,,!,,,,,,,!!!!!! My missus might see it and start making stupid suggestions
On how many bikes I actually need .
This simply won't do .
Surely only the ones near the door are readily available for use, so the ones at the back stay there until the next audit. ..... or maybe you have a winter/summer rearrangement procedureI have perfected the art of bicycle sardines! Would you believe that over 30 of them fit in a single garage?
Yes indeed only about 10 bikes are readily available (by which I mean maybe 30 seconds to extract. But that is genrally enough to be rotating at any one time.Surely only the ones near the door are readily available for use, so the ones at the back stay there until the next audit. ..... or maybe you have a winter/summer rearrangement procedure
