Monkeeee01
Does anyone have any links to any good videos or guides (or just have any tips) on how to set up front and rear mechs (specifically XTR M951/2)?
I know there are loads of videos on YouTube etc and I’ve watched a fair few, but I’m still pretty rubbish at it and always end up taking my bike to my LBS once I’ve installed and run cables.
I can obviously install and connect the cables etc but when it comes to getting them smoothly shifting through the gears I don’t seem to be able to make much progress.
In particular I’m trying to get my front mech to work, my understanding is to put the shifter into the smallest / granny ring gear and then pull the cable tight and securely connect the cable to the mech. However when I then attempt to click the shifter to change the gear, it won’t even click as it’s too tight - but yet the actual cable running under the down tube is really slack??
I’d really like to be able to set them up my self and not have to take my bike to the shop and pay them every time I build a new bike or swap shit between them.
Any help/advice or links to docs/videos would be massively appreciated.
Thanks in advance
Thanks in advance
