Sold Specialized Stumpjumper fsr
Paul End
Original Stumpjumper, plus another set of wheels I used.
£500
Front suspension needs attention
Worthing Sussex.
Did you manage to sort out the rear shock?
Mine is in a similarly slack state.
Those shocks are easily stripped and cleaned / reassembled. You may well just a good clean and reassemble will sort it. Worked for me. I found my leak was just the valve inner. Which is 50p to replace.
Thanks, that’s reassuring.
Just found a rebuild video from Risse Racing on YouTube so will probably have a crack at it myself.
Cheers.
