V Brakes on a '94 Kona...Any ideas how???
Jimmy oldskool
Breezer Fan
As the title...I have this little Fire mountain that is lovely, just needs a spec uplift and I want to put V's on it but my head is fried by the little collar cable guide around the seat tube...any ideas? 🤔
Some people drill the collar out and run the cable through it or put a cable stop in it. You can also buy clamp on stops for the cable. Personally I have always just ran full length outers and removed the clamp, works fine but you need to zip tie the cable on.
thats similar to my 1995 rockhopper.
i had a tube around the seat post so i just used full length cables and secured to the top tube with a small clamp i got off aliexpress.
Those little collars used to go for pretty good money - those and the square front fork mount cable stop. Not sure about now but don't chuck it before checking.
Back in the day I solved the problem with an old Animal watch strap.
I've always wondered why these clamps mounted on the top tube when it would look nicer on the seat tube.
