I recently acqured a 94 AA with rear brake booster - this is how it was set up. Disassembled now but I can pop in the garage and measure the bolts and get pictures of the spacers if that would help? The bits betwen the brakes and booster seem to be standoff spacers (having Googled) as described above by @rigidftwSo I need help with the two cantilever bot for the back brakes. I think I need 5mm x 40mm to get the booster mounted up, does this sound right? Also what can I use for a spacer?
added pics - bolt is 45mm long, with the spacer looing to be 16mm in length, 10mm external and 7mm internal width...
